cortex-M
context_gcc.S文件编译问题
发布于 2015-07-23 11:50:04 浏览:6757
报错信息如下: ``` Building file: ../RTThread_OS/Porting/libcpu/arm/cortex-m4/context_gcc.S Invoking: Cross ARM GNU Assembler arm-none-eabi-gcc -mcpu=cortex-m4 -mthumb -mthumb-interwork -mfloat-abi=hard -mfpu=fpv4-sp-d16 -Og -fmessage-length=0 -fsigned-char -ffunction-sections -fdata-sections -ffreestanding -fno-move-loop-invariants -Wall -Wextra -g3 -x assembler-with-cpp -DDEBUG -DUSE_FULL_ASSERT -DSTM32F407xx -DUSE_HAL_DRIVER -DHSE_VALUE=8000000 -DSTM32F40XX -I"D:ProjectCaoProjectCodeTrafficLightTerminal_gccRTThread_OSPortinglibcpuarmcommon" -I"D:ProjectCaoProjectCodeTrafficLightTerminal_gccRTThread_OSPortinglibcpuarmcortex-m4" -I"D:ProjectCaoProjectCodeTrafficLightTerminal_gccRTThread_OSPortinglibcpuarmstartup" -MMD -MP -MF"RTThread_OS/Porting/libcpu/arm/cortex-m4/context_gcc.d" -MT"RTThread_OS/Porting/libcpu/arm/cortex-m4/context_gcc.o" -c -o "RTThread_OS/Porting/libcpu/arm/cortex-m4/context_gcc.o" "../RTThread_OS/Porting/libcpu/arm/cortex-m4/context_gcc.S" ../RTThread_OS/Porting/libcpu/arm/cortex-m4/context_gcc.S: Assembler messages: ../RTThread_OS/Porting/libcpu/arm/cortex-m4/context_gcc.S:113: Error: thumb conditional instruction should be in IT block -- `vstmdbeq r1!,{d8-d15}' ../RTThread_OS/Porting/libcpu/arm/cortex-m4/context_gcc.S:122: Error: thumb conditional instruction should be in IT block -- `moveq r4,#0x01' ../RTThread_OS/Porting/libcpu/arm/cortex-m4/context_gcc.S:143: Error: thumb conditional instruction should be in IT block -- `vldmiane r1!,{d8-d15}' ../RTThread_OS/Porting/libcpu/arm/cortex-m4/context_gcc.S:155: Error: thumb conditional instruction should be in IT block -- `bicne lr,lr,#0x10' make: *** [RTThread_OS/Porting/libcpu/arm/cortex-m4/context_gcc.o] Error 1 RTThread_OS/Porting/libcpu/arm/cortex-m4/subdir.mk:25: recipe for target 'RTThread_OS/Porting/libcpu/arm/cortex-m4/context_gcc.o' failed ``` 错误点如: ```c #if defined (__VFP_FP__) && !defined(__SOFTFP__) TST lr, #0x10 /* if(!EXC_RETURN[4]) */ VSTMDBEQ r1!, {d8 - d15} /* push FPU register s16~s31 */ #endif ``` 貌似是`VSTMDBEQ` 有问题 我的硬件是STM32F407 我的环境是Windows,使用编译器为gcc-arm-none-eabi-4_9,IDE使用的是Eclipse 因为项目需要,需使用STemWin,而M4内核的STemWin都是要求有使用FPU的,现在就出现了这样的问题,怎么解决? 论坛里面有如下信息: (1).选自 [移植 RT-Thread 到 STM32F4XX (支持FPU)](https://club.rt-thread.org/ask/question/010e96e457d98bfb.html) Cortex-M4F笔记: 1. IAR 和 GCC不支持 VSTMFD,修改为直接使用DB, IA. (2).有人问了同样的问题,选自 [编译遇到的新问题](https://club.rt-thread.org/ask/question/336ecba509943a1c.html) 但是貌似没有准确的回答,后面也没下文
huzhiyuan
2015-07-23
应该是组合指令的关系,出错的地方指令为: VSTMDBEQ、MOVEQ、VLDMIANE、BICNE 都是VSTMDB、MOV、VLDMIA、BIC指令和EQ、NE的组合指令; 而指令VSTMDB、MOV、VLDMIA、BIC本身是能被GCC编译器识别的 解决方向是换种方式写这几句就行了
2015-07-23
主要是后面EQ,要更新编译参数的。 `-mimplicit-it=thumb`
huzhiyuan
2015-07-23
>主要是后面EQ,要更新编译参数的。 `-Wa,-mimplicit-it=thumb` 对,在`C/C++ Build-Settings-Tool Setting-Taarget Processor-Other target flags`一栏中填上 就能编译好了 mark下 [s:154]
moebius.ever
2018-03-04
我用sw4stm32自带的编译器,6.3.1的有这个问题 在windows中,打包好的env 自带的gnu_gcc工具编译时没有这个问题,编译器版本是5.4.1。 没有具体探究是什么问题 不好意思,跟编译器无关,还是有这个问题,正在寻找解决方案中!
2018-03-05
上面说了,这个组合指令需要在编译时加参数,请检查确认。
moebius.ever
2018-03-05
>上面说了,这个组合指令需要在编译时加参数,请检查确认。 是的,加 `-Wa,-mimplicit-it=thumb` 这个可以了,暂时没有弄明白为什么
shauew
2018-05-08
>对,在`C/C++ Build-Settings-Tool Setting-Taarget Processor-Other target flags` 一栏中填上 就能编译好 ... MARK
Dryad
2018-08-27
赞一个,用gcc,碰到这个问题头疼
wh_zhangll
2023-04-03
See through the appearance to perceive the essence.
IT指令是在Thumb-2指令集(16/32位混合指令集)引入的,而你现在指定编译器生成的代码是是Thumb(16位指令集)指令集,你想在指定编译出来的汇编代码是Thumb指令集的,又想使用IT指令的话需要加上参数-mimplicit-it=thumb。
6.8k
huzhiyuan
Cortex-A+M共通的版本
Cortex-M0 不支持 CPSID F指令么?
RT-Thread 有没有Cortex-M7内核的BSP吗?
关于上下文切换上文保存的问题
为什么执行2次,LDR r0,[r0],求教
请教cortex-m4编译遇到的新问题
函数编译后本身地址会加一导致出错
新手请教移植问题 [TOSHIBA M3单片机]
STM32F4上,内核无法启动,无法进入PendSV中断【求助】
【24嵌入式设计大赛】基于ulog日志管理系统
关于使用使用STLINK在RT-Studio里下载程序失败的问题的可能的解决方法
RVBacktrace RISC-V极简栈回溯组件V1.2
ESP32C3环境搭建教程
在OpenMV工程的基础上进行多模态机器人的开发
rv666
道友
Licy
rv666
王依依
rtt_dmx
jaffer
