有关CAN总线通信的几个问题
发布于 2022-02-03 16:56:58 浏览:1178
最近在研究CAN总线,有几个问题不是很明白 1.CANH和CANL必须要并联一个120Ω电阻吗![Inked1_LI.jpg](https://oss-club.rt-thread.org/uploads/20220203/a128214ccfd6a25a5ab4c9f95495121b.jpg.webp) 2.为什么总线模式必须要设置为RT_CAN_MODE_LOOPBACK,rt_device_write才不会报错![3.jpg](https://oss-club.rt-thread.org/uploads/20220203/354e2a78f29c58a7b1bf22e6dbd09c81.jpg.webp) 3.为什么rt_device_write执行之后,在PC上的USB-CAN Tool软件中接收不到刚发出来的信息![4.jpg](https://oss-club.rt-thread.org/uploads/20220203/2743a2a91598941efecc4218ca4c65d9.jpg.webp) 我使用的代码如下``` /*CAN设备操作*/ rt_err_t can_ret = 0; rt_size_t size = 0; struct rt_can_msg msg = { 0 }; //can1使用PA11 PA12引脚 can_dev = rt_device_find(CAN_DEV_NAME); if (can_dev == RT_NULL) { LOG_E("rt_device_find [can1] failed...\n"); return -EINVAL; } //以中断接收及发送模式打开 CAN设备 can_ret = rt_device_open(can_dev, RT_DEVICE_FLAG_INT_TX | RT_DEVICE_FLAG_INT_RX); if (can_ret < 0) { LOG_E("rt_device_open [can1] failed...\n"); return can_ret; } //设置 CAN 通信的波特率为 500kbit/s can_ret = rt_device_control(can_dev, RT_CAN_CMD_SET_BAUD, (void *) CAN500kBaud); //获取 CAN 总线设备的状态 can_ret = rt_device_control(can_dev, RT_CAN_CMD_GET_STATUS, &status); can_ret = rt_device_control(can_dev, RT_CAN_CMD_SET_MODE, (void *)RT_CAN_MODE_LOOPBACK); LOG_D("can bus current status:%d", can_ret); //初始化CAN接收信号量 rt_sem_init(&can_sem, "can_sem", 0, RT_IPC_FLAG_FIFO); //创建CAN接收线程,并开启 can_th = rt_thread_create("can_rx", can_rx_thread, RT_NULL, 1024, 25, 10); if (can_th != RT_NULL) { rt_thread_startup(can_th); } else { rt_kprintf("create can_rx thread failed!\n"); } msg.id = 0x78; /* ID 为 0x78 */ msg.ide = RT_CAN_STDID; /* 标准格式 */ msg.rtr = RT_CAN_DTR; /* 数据帧 */ msg.len = 8; /* 数据长度为 8 */ /* 待发送的 8 字节数据 */ msg.data[0] = 0x00; msg.data[1] = 0x11; msg.data[2] = 0x22; msg.data[3] = 0x33; msg.data[4] = 0x44; msg.data[5] = 0x55; msg.data[6] = 0x66; msg.data[7] = 0x77; /* 发送一帧 CAN 数据 */ size = rt_device_write(can_dev, 0, &msg, sizeof(msg)); if (size == 0) { rt_kprintf("can_dev write data failed!\n"); } ```
2022-02-04
学以致用
- CAN的引脚配置了吗? - 如果对CAN通信不熟悉,建议先用ST的官方裸机例程调通,这样对CAN有个概念,再使用RT-Thread调试,会清楚很多
GeorgeZZQ
2022-02-06
哦,这一步我也完成了![5.jpg](https://oss-club.rt-thread.org/uploads/20220206/8451683cbd3eddd2d99ded99acc98895.jpg.webp)
lqwuliang
2022-02-08
天下没有解决不了的bug,只有发现不了的bug.
我也用RTT,但没用RTT驱动。可以先用其他板子例程跑下can,熟悉下先
2022-02-08
http://bbs.eeworld.com.cn/thread-1193241-1-1.html可以去看看我的贴子。
1.2k
GeorgeZZQ
谁有STM32裸跑的CANopen程序啊???
CAN驱动程序框架
CAN驱动接口如何规范一下
STM32F10XCAN驱动使用的问题
rtthread2.1.0下,找不到can1设备
