用stm32F103测试CAN例程,始终发送失败 求助!!!
发布于 2020-08-03 09:58:36 浏览:3070
单片机用的是STM32F103CBT6 RTT版本是lts-v3.1.4 将BSP里的CAN驱动.c和.h加入到工程 开启宏定义#define BSP_USING_CAN #define BSP_USING_CAN1 CubeMX生成的HAL_CAN_MspInit(CAN_HandleTypeDef* hcan)函数加入到board.c 板子通过CAN盒连接到电脑,用CANtest接收 修改CAN例程为周期发送,后附代码 问题:控制台通过list_device可以看到CAN1已经注册,运行例程始终发送失败, \ | / - RT - Thread Operating System / | \ 3.1.4 build Jul 31 2020 2006 - 2019 Copyright by rt-thread team [D/main] Hello RT-Thread! msh >list_device device type ref count ------ -------------------- ---------- can1 CAN Device 0 uart2 Character Device 2 pin Miscellaneous Device 0 msh >can_sample can dev write data failed! can dev write data failed! can dev write data failed! can dev write data failed! can dev write data failed! can dev write data failed! can dev write data failed! #include
#include "rtdevice.h" #define CAN_DEV_NAME "can1" /* CAN 设备名称 */ static rt_device_t can_dev; /* CAN 设备句柄 */ int can_sample(int argc, char *argv[]) { struct rt_can_msg msg = {0}; rt_err_t res; rt_size_t size; can_dev = rt_device_find(CAN_DEV_NAME); if (!can_dev) { rt_kprintf("find %s failed!\n", CAN_DEV_NAME); return RT_ERROR; } /* 以中断接收及发送方式打开CAN设备 */ res = rt_device_open(can_dev, RT_DEVICE_FLAG_INT_TX | RT_DEVICE_FLAG_INT_RX); RT_ASSERT(res == RT_EOK); rt_device_control(can_dev, RT_CAN_CMD_SET_MODE, (void *)RT_CAN_MODE_NORMAL); rt_device_control(can_dev, RT_CAN_CMD_SET_BAUD,(void *)CAN250kBaud); msg.id = 0x78; /* ID为0x78 */ msg.ide = RT_CAN_STDID; /* 标准格式 */ msg.rtr = RT_CAN_DTR; /* 数据帧 */ msg.len = 8; /* 数据长度为8 */ /* 待发送的8字节数据 */ msg.data[0] = 0x00; msg.data[1] = 0x11; msg.data[2] = 0x22; msg.data[3] = 0x33; msg.data[4] = 0x44; msg.data[5] = 0x55; msg.data[6] = 0x66; msg.data[7] = 0x77; /* 发送一帧CAN数据 */ while(1){ size = rt_device_write(can_dev, 0, &msg, sizeof(msg)); if (size == 0) { rt_kprintf("can dev write data failed!\n"); } rt_thread_mdelay(1000); } return res; } /* 导出到 msh 命令列表中 */ MSH_CMD_EXPORT(can_sample, can device sample);
china_tianshi
2020-08-12
已经解决。 之前将CubeMX生成的HAL_CAN_MspInit(CAN_HandleTypeDef* hcan)函数加入到board.c里不好用,应该是没有调用到这个函数,调用的是HAL库里的__weak void HAL_CAN_MspInit(CAN_HandleTypeDef *hcan) { /* Prevent unused argument(s) compilation warning */ UNUSED(hcan); /* NOTE : This function Should not be modified, when the callback is needed, the HAL_CAN_MspInit could be implemented in the user file */ } 解决办法是将CubeMX生成工程内的stm32f1xx_hal_msp.c文件复制到RTT工程的drivers文件夹下,将其他不用的函数删掉 将包含文件的main.h改为board.h
Ricky_Zhang
2020-08-26
我现在也在调试CAN程序,使用回环模式发送接收成功,但是正常发送模式一直长度一直是0,看现象和这个很类似,能否指导一下?
3.1k
china_tianshi
谁有STM32裸跑的CANopen程序啊???
CAN驱动程序框架
CAN驱动接口如何规范一下
STM32F10XCAN驱动使用的问题
rtthread2.1.0下,找不到can1设备
STM32内存扩展,SRAM-RMC
