通用bootloader
将更新文件下载到download区后,bootloader不跳转
发布于 2021-11-17 18:23:52 浏览:740
问题比较复杂,请听我细细道来。 我把更新文件通过网口,下载到了stm32f427的download分区后 ,重启发现程序并未更新,不知道是怎么回事。 首先,BootLoader的制作,flash分区应该是没有问题的,因为我用Xshell中的Ymodem传输固件,发现能够升级成功。 我的步骤如下: - 1、擦除download分区 - 2、将rtthread.rbl文件,通过网口传输到stm32f427中,每包1kb,边传输边更新download分区flash。 - 3、软件reboot。 网口接收部分代码如下: 接收文件部分: ```c if(cmd == 0x14) { uint8_t buf[paramlen-4]; memcpy(&buf, &data_buf[10], paramlen-4); uint16_t packnumber = 0; packnumber = data_buf[6] + (data_buf[7] << 8); uint16_t packsum = 0; packsum = data_buf[8] + (data_buf[9] << 8); fal_partition_t fal_dev = RT_NULL; int fal_addr = (packnumber-1) * 1024; fal_dev = fal_partition_find("download"); if(fal_dev == RT_NULL) { rt_kprintf("can not find download partition\n"); return ; } if(fal_partition_write(fal_dev, fal_addr, buf, paramlen-4) < 0) { rt_kprintf("fal write download partition addr:%x size:%d fail\n"); return ; } rt_kprintf("receive length: %d packnumber: %d packsum: %d fal_addr: %d buf0: %x \r\n", paramlen-4,packnumber,packsum,fal_addr,buf[0]); //传输完成 if(packnumber == packsum) { rt_thread_mdelay(1000); rt_hw_cpu_reset(); } } ``` 擦除flash部分: ```cpp fal_partition_t fal_dev = RT_NULL; fal_dev = fal_partition_find("download"); if(fal_dev == RT_NULL) { rt_kprintf("can not find download partition\n"); return 0; } if(fal_partition_erase_all(fal_dev) < 0) { rt_kprintf("erase download partition all fail\n"); return 0; } else { rt_kprintf("erase download partition all success\n"); } ``` 上位机是用Qt做的部分代码如下: ```cpp void MainWindow::slot_update() { qDebug() << "update"; if(!filepath.isNull()) { //初始 QFile* file = new QFile(filepath, this); qDebug() << "filename = " << file->fileName(); qDebug() << "size = " << file->size(); //打开 if (!file->open(QIODevice::ReadOnly | QIODevice::Text)) return; //读取 QByteArray data = file->readAll(); qDebug() << "qbytesize = " << data.size(); //拆包发送 每包1024 const int packsize = 1024; int num = data.size()/packsize + 1; for(int i=0 ; i
write(SendData); ui->bar_update->setValue( (i+1)*100/num ); //下面这个函数很重要 socket->waitForBytesWritten(); QThread::msleep(200); } } else { QMessageBox::critical(this,"critical","没有选择升级文件"); } } ``` 打印信息: ![image.png](https://oss-club.rt-thread.org/uploads/20211117/941ffab54656490ee125cf3e479da880.png.webp) ![image.png](https://oss-club.rt-thread.org/uploads/20211117/98b346ed894f37e22b9309bd288ed447.png.webp) 经查,每个包的第一个uint8都没问题,传输应该未丢包 ![image.png](https://oss-club.rt-thread.org/uploads/20211117/6bcb708d46f87c59b4f44328a69a7b12.png.webp) 第一次做ota升级,各位老工程师们帮帮孩子。 是传输完成,写入flash后还要进行什么操作么? 我写到flash的download分区后,就直接rt_hw_cpu_reset();了
2021-11-17
如果我来调:等网络传输完后,我用JTAG把download区读回来对比校验,看是否完整写入应该就可以发现问题。 boot只是在启动时检查download是否完整,且有更新。不管里面数据怎么来的。
龙王赘婿
2021-11-19
油腻才是必杀技
问题已经解决了,解决方法: - 1、用自己的ota升级过后,先用jlink连接板子,打开jflash并选择对应芯片型号,file->new Project; - 2、连接板子并读出`flash,target->connect, target->manual programing->read back->entire chip;`此时可读到板子对应寄存器的值 - 3、`flash,target->connect, target->manual programing->read back->range`,读取对应地址的值,我的是download分区`0x08080000 - 0x080e0000`,并保存为bin文件`file->save date file as`选择文件类型为bin。 - 4、比对文件,先用`beyond compare`比对,发现是有文件不同,但是无法直观查看,于是我用winhex打开对比,发现是有些byte缺失。 - 5、后来发现,传输与写入并无问题,最后检查出,原来是qt读取文件的问题,在读取文件时使能了QIODevice::Text,这个参数会导致读取二进制文件时,造成一些转义字符无法读取。修改后就成功了。 ```c // if (!file->open(QIODevice::ReadOnly | QIODevice::Text)) if (!file->open(QIODevice::ReadOnly)) ```
740
龙王赘婿
油腻才是必杀技
进入bootloader的方式探讨
求助:IAP里的APP使用的RTT,跳转后出错。[已解决]
想做网口的IAP远程升级,不知可不可行
IAP问题
