Default_Handler
HAL
使用HAL CAN驱动中断发送,报Default_Handler,如何解决?
发布于 2020-07-26 00:44:49 浏览:3219
使用RTThread Studio新建基于STM32F7芯片的4.0.2工程,stm32f7xx_hal_conf.h开启HAL_CAN_MODULE_ENABLED,自己编写基于HAL库的CAN初始化并开启TX、RX中断,main中每秒发送一帧数据,当第一次发送成功后即将产生TX中断时进入Default_Handler,程序死掉。 ```c static void CAN1_IOInit(void) { GPIO_InitTypeDef GPIO_InitStruct = {0}; __HAL_RCC_CAN1_CLK_ENABLE(); __HAL_RCC_GPIOA_CLK_ENABLE(); GPIO_InitStruct.Pin = GPIO_PIN_11|GPIO_PIN_12; GPIO_InitStruct.Mode = GPIO_MODE_AF_OD; GPIO_InitStruct.Pull = GPIO_PULLUP; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF9_CAN1; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); HAL_NVIC_SetPriority(CAN1_RX0_IRQn, 7, 0); HAL_NVIC_EnableIRQ(CAN1_RX0_IRQn); HAL_NVIC_SetPriority(CAN1_TX_IRQn, 5, 0); HAL_NVIC_EnableIRQ(CAN1_TX_IRQn); } static void CAN1_Init(void) { hcan1.Instance = CAN1; hcan1.Init.Prescaler = 6; hcan1.Init.Mode = CAN_MODE_NORMAL; hcan1.Init.SyncJumpWidth = CAN_SJW_2TQ; hcan1.Init.TimeSeg1 = CAN_BS1_10TQ; hcan1.Init.TimeSeg2 = CAN_BS2_7TQ; hcan1.Init.TimeTriggeredMode = DISABLE; hcan1.Init.AutoBusOff = DISABLE; hcan1.Init.AutoWakeUp = DISABLE; hcan1.Init.AutoRetransmission = DISABLE; hcan1.Init.ReceiveFifoLocked = DISABLE; hcan1.Init.TransmitFifoPriority = DISABLE; if (HAL_CAN_Init(&hcan1) != HAL_OK) { Error_Handler(); } } static void CAN1_FilterInit(void) { CAN_FilterTypeDef CAN_Filter = {0}; CAN_Filter.FilterIdHigh = 0x0000; CAN_Filter.FilterIdLow = 0x0000; CAN_Filter.FilterMaskIdHigh = 0x0000; CAN_Filter.FilterMaskIdLow = 0x0000; CAN_Filter.FilterFIFOAssignment = CAN_FILTER_FIFO0; CAN_Filter.FilterBank = 0; CAN_Filter.FilterMode = CAN_FILTERMODE_IDMASK; CAN_Filter.FilterScale = CAN_FILTERSCALE_32BIT; CAN_Filter.FilterActivation = ENABLE; CAN_Filter.SlaveStartFilterBank = 14; if (HAL_CAN_ConfigFilter(&hcan1, &CAN_Filter) != HAL_OK) { Error_Handler(); } } static void CAN1_Start(void) { if (HAL_CAN_Start(&hcan1) != HAL_OK) { Error_Handler(); } if (HAL_CAN_ActivateNotification(&hcan1, CAN_IT_RX_FIFO0_MSG_PENDING | CAN_IT_TX_MAILBOX_EMPTY) != HAL_OK) { Error_Handler(); } } ``` main中每秒执行 ```c if (HAL_CAN_AddTxMessage(&hcan1, &CAN_TxHeader, &(aData[0]), &TxMailbox) != HAL_OK) { Error_Handler(); } ``` 总线上能收到一次发送的数据后再也收不到数据,跟踪程序进入 ``` .section .text.Default_Handler,"ax",%progbits Default_Handler: Infinite_Loop: b Infinite_Loop .size Default_Handler, .-Default_Handler ``` 请问该问题如何解决? 调用栈为: ``` WWDG_IRQHandler() at startup_stm32f767xx.S:127 0x80065d0
() at 0xfffffffd rt_hw_interrupt_thread_switch() at context_gcc.S:213 0x8000336 rt_system_scheduler_start() at scheduler.c:174 0x8001c50 rt_thread_stack() at 0x20021178 ```
2020-07-26
说明你没写中断服务函数,所以默认进 Default_Handler。 要确认哪个中断没写,在 Default_Handler 中看当前的 IPSR 即可得到中断号,记得减去内核中断16个。
15682532888
2020-07-28
谢谢指导,问题已解决。新版的需要手动加中断服务函数CAN1_TX_IRQHandler。
Jacksi
2020-08-29
感谢指导,我也遇见了类似的问题,使用裸机ADC中断时因为没有写中断处理函数导致进入 Default_Handler。我之前使用CubeMX生成的代码里面自动包含了ADC中断处理函数,所以直接使用HAL库提供的接口回调函数没有问题,RTT里面需要自己添加中断处理函数,找了很久的问题,多谢本贴。
3.2k
15682532888
谁有STM32裸跑的CANopen程序啊???
CAN驱动程序框架
CAN驱动接口如何规范一下
STM32F10XCAN驱动使用的问题
rtthread2.1.0下,找不到can1设备
STM32内存扩展,SRAM-RMC
tjrong
yans
alight
Pai同学
Rick98
WenShan
