RTT Studio can配置问题求助
发布于 2022-11-23 13:13:32 浏览:925
[tocm]  ## 第二步  ## 第三步  4.10中发现 驱动里面已经有can配置文件了  ## 第四步 cubemx 中的时钟替换rtt的时钟  ## 第五步 复制can例程 微小改动 app_can1.c ```c #include "app_can1.h" #define CAN_DEV_NAME "can1" /* CAN 设备名称 */ static struct rt_semaphore rx_sem; /* 用于接收消息的信号量 */ static rt_device_t can_dev; /* CAN 设备句柄 */ /* 接收数据回调函数 */ static rt_err_t can_rx_call(rt_device_t dev, rt_size_t size) { /* CAN 接收到数据后产生中断,调用此回调函数,然后发送接收信号量 */ rt_sem_release(&rx_sem); return RT_EOK; } static void can_rx_thread(void *parameter) { int i; rt_err_t res; struct rt_can_msg rxmsg = {0}; /* 设置接收回调函数 */ rt_device_set_rx_indicate(can_dev, can_rx_call); #ifdef RT_CAN_USING_HDR struct rt_can_filter_item items[5] = { RT_CAN_FILTER_ITEM_INIT(0x100, 0, 0, 0, 0x700, RT_NULL, RT_NULL), /* std,match ID:0x100~0x1ff,hdr 为 - 1,设置默认过滤表 */ RT_CAN_FILTER_ITEM_INIT(0x300, 0, 0, 0, 0x700, RT_NULL, RT_NULL), /* std,match ID:0x300~0x3ff,hdr 为 - 1 */ RT_CAN_FILTER_ITEM_INIT(0x211, 0, 0, 0, 0x7ff, RT_NULL, RT_NULL), /* std,match ID:0x211,hdr 为 - 1 */ RT_CAN_FILTER_STD_INIT(0x486, RT_NULL, RT_NULL), /* std,match ID:0x486,hdr 为 - 1 */ {0x555, 0, 0, 0, 0x7ff, 7,} /* std,match ID:0x555,hdr 为 7,指定设置 7 号过滤表 */ }; struct rt_can_filter_config cfg = {5, 1, items}; /* 一共有 5 个过滤表 */ /* 设置硬件过滤表 */ res = rt_device_control(can_dev, RT_CAN_CMD_SET_FILTER, &cfg); RT_ASSERT(res == RT_EOK); #endif while (1) { /* hdr 值为 - 1,表示直接从 uselist 链表读取数据 */ rxmsg.hdr = -1; /* 阻塞等待接收信号量 */ rt_sem_take(&rx_sem, RT_WAITING_FOREVER); /* 从 CAN 读取一帧数据 */ rt_device_read(can_dev, 0, &rxmsg, sizeof(rxmsg)); /* 打印数据 ID 及内容 */ rt_kprintf("ID:%x", rxmsg.id); for (i = 0; i < 8; i++) { rt_kprintf("%2x", rxmsg.data[i]); } rt_kprintf("\n"); } } int CreatCAN1_Entry(void) { struct rt_can_msg msg = {0}; rt_err_t res; rt_size_t size; rt_thread_t thread; // char can_name[RT_NAME_MAX]; // if (argc == 2) // { // rt_strncpy(can_name, argv[1], RT_NAME_MAX); // } // else // { // rt_strncpy(can_name, CAN_DEV_NAME, RT_NAME_MAX); // } /* 查找 CAN 设备 */ can_dev = rt_device_find(CAN_DEV_NAME); if (!can_dev) { rt_kprintf("find %s failed!\n", CAN_DEV_NAME); return RT_ERROR; } /* 初始化 CAN 接收信号量 */ rt_sem_init(&rx_sem, "rx_sem", 0, RT_IPC_FLAG_FIFO); /* 以中断接收及发送方式打开 CAN 设备 */ res = rt_device_open(can_dev, RT_DEVICE_FLAG_INT_TX | RT_DEVICE_FLAG_INT_RX); RT_ASSERT(res == RT_EOK); /* 创建数据接收线程 */ thread = rt_thread_create("can_rx", can_rx_thread, RT_NULL, 1024, 25, 10); if (thread != RT_NULL) { rt_thread_startup(thread); rt_kprintf("create can_rx thread sucess!\n"); } else { rt_kprintf("create can_rx thread failed!\n"); } msg.id = 0x78; /* ID 为 0x78 */ msg.ide = RT_CAN_STDID; /* 标准格式 */ msg.rtr = RT_CAN_DTR; /* 数据帧 */ msg.len = 8; /* 数据长度为 8 */ /* 待发送的 8 字节数据 */ msg.data[0] = 0x00; msg.data[1] = 0x11; msg.data[2] = 0x22; msg.data[3] = 0x33; msg.data[4] = 0x44; msg.data[5] = 0x55; msg.data[6] = 0x66; msg.data[7] = 0x77; /* 发送一帧 CAN 数据 */ size = rt_device_write(can_dev, 0, &msg, sizeof(msg)); if (size == 0) { rt_kprintf("can dev write data failed!\n"); } return res; } ``` app_can1.h ```c #ifndef APPLICATIONS_APP_CAN1_H_ #define APPLICATIONS_APP_CAN1_H_ #include
#include "rtdevice.h"//配制串口数据引用 #include "rtdef.h" extern int CreatCAN1_Entry( void); #endif ``` 不知道为啥总是卡在RT_ASSERT  求大神指点哪儿错了
2022-11-24
board.h中添加这两行代码没 ```c #define BSP_USING_CAN #define BSP_USING_CAN1 ```
925
000
谁有STM32裸跑的CANopen程序啊???
CAN驱动程序框架
CAN驱动接口如何规范一下
STM32F10XCAN驱动使用的问题
rtthread2.1.0下,找不到can1设备
pkgs --upgrade报错SSL未验证问题解决记录
CherryUSB STM32 glue 新增初始化
求助can通讯下怎末运用485
STM32F407ZGT适配串口V2驱动
818
